  #13   Ban this user!
Old 12-06-2005, 08:19 PM
garagefela is on a distinguished road
Hey Wigit,
.005" thats nothing!!! Ahh its actually a lot as I am a machinist by trade, but I mean .005" is not a lot when you look at the amount of material taken out, very impressed with the final result.
I have been trying to decide what the actual base of my router will be and did not really want to make a T slotted table as I thought/knew it would end up like a banana.
It seems from your experience that this is not the case. I was always looking at plate but still deciding on tapped holes to hold down top MDF board but your table looks like the go
Can you tell me what grade the plate is?
Cheers M
Old 12-06-2005, 09:25 PM
widgitmaster's Avatar
Gold Member
widgitmaster is on a distinguished road
Cool
Originally Posted by garagefela
Hey Wigit,
Cheers M
Thanks!
The plates are made from blanchard ground cast aluminum, 2024 MIC-6 Cuts really nice, doesn't warp, scratches really easily (important for new sales)
Not too bad for an old-fart in the garage eah!
I made 4pc 24x12 today! Got more chips now!
Eric
  #15   Ban this user!
Old 12-06-2005, 09:35 PM
CNCRob's Avatar
Moderator
CNCRob is on a distinguished road
All your parts look great Eric.
  #16   Ban this user!
Old 12-08-2005, 03:20 AM
mxpro32 is on a distinguished road
yeah mic 6 is really nice stuff if strength is not you primary concern because it is pretty soft. It is cast and cooled in such a way that most of the internal stresses are relieved, I'm pretty sure you are supposed to be able to machine 90% of the thickness off without warping due to internal stresses. Not too sure about mic 6 being 2024 though. nice looking products you've got.
Old 12-08-2005, 04:49 PM
Gold Member
Cool
If Im not mistaken, MIC-6 is a tradename from Alcoa Aluminum!
http://www.alcoa.com/industrial/en/p...34&prod_id=619
Here is a little fixture I made to drill the holes in the Delrin Acme nuts!
All i need to do was slide the block in the vise till it hit the stop, set zero in the middle of the block, move over .5625 and drill 3/16" holes!
Screw on another nut, then drill all four holes again!
Easier to use than setting up the collet index fixture!
Eric
ID:	12668   Click image for larger version
ID:	12669   Click image for larger version
  #18   Ban this user!
Old 12-09-2005, 02:04 AM
Thats a neat drill jig you made. How exactly does it work? are you just centering, then zeroing you dro and drilling the four holes? I've got to get a DRO for my mill.
Old 12-09-2005, 07:21 AM
Gold Member
Cool
I use a dial indicator to set the center of the spindle to the center of the screw, then I move the table once to a distance of .5625 to drill the holes.
Then I open the vise, rotate the fixture, drill the next hole!
The Acme screw is made to be in the center of the square block, so the distance to all 4 holes is cymetrical from center. This can be done with or without a DRO!
  #20   Ban this user!
Old 12-12-2005, 06:35 PM
titchener is on a distinguished road
What kind of lube/coolant system are you using?
Eric-
Nice work. I'm looking for a minimal mess cutting lube/coolant system and I noticed the feed lines to a lube on your mill, can you tell me what you're using on your mill and how well it works and if you would recommend it?
Thanks,
Paul T.
  #21   Ban this user!
Old 12-12-2005, 07:31 PM
Parameter is on a distinguished road
Would you ship to Canada, your ebay site only says US? I'd love to have 2 of those nuts.
Para
Paraman, Parabeast, Paramachine, Parameter.
The many in one and the one in the many.
Old 12-12-2005, 09:24 PM
Gold Member
Cool
Originally Posted by titchener
Eric-
Thanks,
Paul T.
I got the tankless "KoolMist" unit m# 891-5987 from enco.com
http://www.use-enco.com/CGI/INSRAR?PMSECT=0002003608
(requires an air compressor)
Also got a gallon of their coolent mix, It works really well when mixing 2-shotglasses to 1-gallon of water. Too much hurts my nose, too little rusts the machinery!
I hang the jug on the back of the machine, mounted the on/off valve to the ram for easy access, ran the knozzle down close to the cutter. Knozzle is adjustable, more air less liquid / more liquid less air...
When cutting plexiglas, it gives an almost polished finish!
Eric
Old 12-12-2005, 09:28 PM
Gold Member
Cool
Para
Yes, I'll ship to CANADA!
Send me a privaste msg with contact info.
Skip eBay, Good deals for "Zoned" customers!
Eric
