Results 1 to 5 of 5
Thread: 1994 bridgeport 760-22 start up error
    Dec 2011
    Usa
    Just purchased a 1994 bridgeport 760-22 with DX-32 controller.
    Machine sat for 6 months unplugged, just got power feed to hook it up, first time using this machine
    when booting up machine says
    HDD CONTROLLER failure
    Press F1 to resume.
    When pressing F1 it says drive not ready
    insert boot disk into A and press any key when ready.
    We dont have the boot disk, not sure if we are missing that or if this is a software issue.
    checked all power & ribbon cables plugged into hard drive and all seems to check out.
    Any help would be appreciated.
    Apr 2005
    Check your PM box (top right of web page)
    Dec 2010
    hard drive
    Had the same problem. Sounds like the hard drive. The computer is most likely a 386. It is in ours. Went to a local computer shop with the old drive and found an old used one that worked for $10.00. The shop got the data off of the old drive and installed it on the replacement. Over a year with no problems.
    Aug 2011
    Possible your CMOS battery is dead and lost all your CMOS settings
    Now it doesnt know your hard drive parameters.
    hopefully your hard drive is still fine and you can just replace the battery on your motherboard and auto detect your harddrive or reset the parameters.
    if you need a motherboard pm me I have a couple.
    Good luck
    Registered holbieone's Avatar
    Feb 2007
    on boot up press , DEL or F1 to boot into the bios
    then save and exit
    if your system comes up you have a bad cmos battery
    1. 1994 haas vf2 error codes 161 139 103
      By duckslayer in forum Haas Mills
      Last Post: 02-21-2012, 09:17 AM
    2. START UP ERROR
      By cnckid in forum Cincinnati CNC
      Last Post: 12-13-2011, 11:34 AM
    3. Need Help!- 1994 Bridgeport V2XT/ SX 15 CONTROL
      By DF-ENTERPRISES in forum Bridgeport and Hardinge Mills
      Last Post: 06-27-2011, 01:23 AM
    4. Need Help!- MH 800 C start up error
      By preimerx5 in forum Deckel, Maho, Aciera, Abene Mills
      Last Post: 03-03-2011, 07:57 AM
    5. 1994 Bridgeport V2xt
      Last Post: 09-26-2007, 12:09 PM
