Are all of your drives the same? Can you swap two of them and see if the problem follows the drive board or is the problem isolated to a particular axis/motor/wiring.
I had a drive board give me intermittent problems and found a cold solder joint in the pcboard terminals that were going out to the motor. A five minute fix with a soldering iron made it go away permanently.
LinkBack URL
About LinkBacks
