Results 1 to 4 of 4
Thread: Best way to mount pulley and handle on knee drive
    Mar 2012
    I have been trying to come up with some kind of elegant way to mount the knee drive pulley on the shaft of my Bridgeport while retaining use of the manual crank handle and the original dial. I have attached a picture of the parts for reference. As we all know the wheel dial and locking knurled nut normally go on first then the drive coupling splined piece (whatever it is called) slides on the shaft and engages with the key on the shaft under the part that the dial goes on and the handle goes on the remaining part of the protruding shaft. Obviously there is no shaft left over for the pulley.
    What I am trying to accomplish is that I need the pulley mounted on fairly close to the bottom of the stack then I want to be able to retain the original dial and locking mechanism and handle. What methods have other people used to stack all these parts up and make it work? Can this be accomplished without having to make a new longer shaft?
    All I know for sure so far is that I will have to machine off the hub of the pulley to get the thickness down some.
    Attached Thumbnails Attached Thumbnails Best way to mount pulley and handle on knee drive-img-20120426-00464.jpg
    May 2004
    Build a coupler/adapter/step shaft to move everything out front of the pulley.
    http://www.kirkcon.com/
    Mar 2012
    Now that I have done a little more research and figured out how to remove the dial holder (http://www.cnczone.com/forums/bridge...rt_mill_-.html) and looked at how some of the Z axis power feeds go on I am thinking the thing to do might be to just make a new bigger shaft to slide over the old one then I can put a keyway in the inside of the new shaft to lock it to the old one, bore out the old dial holder and key it so it slides over the new larger shaft, and make a new handle and clutch mechanism or maybe even I could bore out the old ones for the new larger shaft.
    I would still like to see how others have done this.
    May 2004
    Basically that is what I was saying to do.
  1. Best way to mount a timing pulley on stepper shaft?
    By MaxTheModder in forum Mechanical Calculations/Engineering Design
    Last Post: 02-06-2011, 03:14 AM
  2. New Machine Build- BOB that can step drive and handle encoders
    By xkadet in forum Controller Cards
    Last Post: 12-02-2009, 06:32 PM
  3. Which servo drive can handle AC motor without Hall feedback?
    By scsi in forum Servo Motors and Drives
    Last Post: 10-08-2009, 02:37 AM
  4. Newbie- CNC Lathe - Servo direct drive or pulley drive?
    By s76tools in forum General Metal Working Machines
    Last Post: 09-06-2009, 12:17 PM
  5. Need knee handle for Journeyman 310
    By ken fedirko in forum Tree
    Last Post: 12-21-2007, 02:04 PM
