Old 11-30-2005, 11:35 AM
kayleesdad is on a distinguished road
Bridgeport VMC 1000
I've got a problem with a Bridgeport VMC 1000, when it powers up everything starts like normal then I get Machine Check, Executive Load..wait\C:\> and it stays in this state. Is this an executive file problem? Should I reload the executive files?
Old 11-30-2005, 03:20 PM
FYI, it was the executive files. I couldn't get them to load at first and started to suspect the drive but took everything apart and cleaned it, ran the files and am back up and running.
Old 11-30-2005, 07:42 PM
Moderator
machintek is on a distinguished road
FYI: On the VMC1000 and all Dx32 controlled Bridgeports, if an executive load fails, it means the BMDC.BIN file did not load to the BMDC. It may be as simple as cleaning the BMDC edge connector and plugging it back into the ISA slot. I have also moved it to a new ISA slot. Could also be software, hard drive, CMOS etc.
In the maintenance page go to 0 for more commands and go to tests. there if you choose the B3T test, it tests the BMDC board.
You did well!
George
Old 12-01-2005, 08:38 AM
Thanks for the feedback!
I've got a new problem now. I am getting a run time error M6101:Math. Also getting a Floating point error:Invalid
Any ideas?
Old 12-01-2005, 09:36 AM
I've reseated all of the cards on this rack and have lost my monitor now (everything is plugged in). I defintely have a problem.
Old 12-01-2005, 11:23 AM
To summarize where I am right now....
Yesterday, our VMC 1000 operator called me to the machine saying it was acting funny. The display read Machine Check, Executive Load..wait\C:\> and it would not clear/advance from this state. I was able to get the problem to clear by reloading the executive files. This morning the operator went to start the machine and it gave him a run time error M6101:Math and Floating point error:Invalid. I reseated all of the cards on this rack and have lost my monitor now, I have verified everything is seated properly and that everything is plugged in.
Any ideas? Should this be posted in another forum?
Old 12-01-2005, 02:04 PM
Moderator
There were two versions of the VMC1000. One had a CONTROL IN A BOX and one did not. If your mother board is visible in the top left corner of the cabinet it is not a CIB machine.
Typically the math errors are due to overheating or a low logic power supply.
Most non CIB machines had a heat sink on the processor and no fan. Make sure it has not fallen off. Make sure air filter is clean.
Check your power supply, especially the 5 VDC. Check the P8 and P9 connector of power to the mother board.
Make sure CMOS for the hard drive is correct.
George
Old 12-01-2005, 02:59 PM
I checked the power and it is good, I am strongly suspecting the mother board at this time, it's the only common component for the problems I am having. Thanks for the feedback and please don't hesitate to give me more if you have it.
Old 12-01-2005, 06:40 PM
Moderator
Don't think you can replace it with a dual core 64bit Athalon! The BMDC actually runs the machine but it has a processor speed of about 8MHZ. Since both must talk to each other, we limit a replacement to about 300MHZ. Right now we buy a "all in one" half size motherboard and backplane (which has the necessary ISA slot for the BMDC).
You can even ditch the hard drive by using a DOM (disk on a module, a flash memory device that plugs into an IDE port).
Or you can buy a working 486 PC and use that motherboard. Make sure it is a DX which has the math co-processor.
George
Old 12-02-2005, 07:48 AM
Most of what you said is Chinese to me but it sounds like a great idea. However I ordered a Bridgeport motherboard replacement kit yesterday (before your post) and am expecting it in tomorrow. I'll post the machines status as soon as I install the board/kit. Thanks again.
  #11   Ban this user!
Old 01-09-2006, 11:56 AM
FYI, the kit did the trick.
