Results 1 to 7 of 7
Thread: bridgeport vmc 500 - tool page ?
    Apr 2012
    uk
    hello, going for a job where by i will be using a vmc 500, and have been told that they dont have a seperate tool page, that you put all your tool data in the program ? is this true ?
    Or do i have the option to list the tools in a tool page and call them from the program ?
    Registered christinandavid's Avatar
    Aug 2009
    New Zealand
    Are we talking Heidenhain? If so, try creating a program no. 0 to store tool data in. This option may depend on parameters - I didn't know about it myself until I switched jobs.
    Defining tool data at start of program is not so bad if you are only working on one operation at a time. If you are running multiple ops, set-up a standard sub to define your tools.
    Note that if they are using separate tool lists they are also probably using the dreaded 'zero' tool ....aaaaaaarrrrggghhhh!!!!!!!
    DP
    ps if we are not talking Heidenhain disregard everything I have said...
    Apr 2012
    uk
    yeh heidenhain it is, so they defently dont have a tool page ?
    The idea of have the tool data at the start of the program isnt a massive issue, its just i like to have a few tool i use alot there ready to use, not having to set it all each time, more of a time issue i think.
    Making a Prg 0. sounds like a idea, are they able to call a seperate program ?
    I have not got round to seeing the machine yet so cant say much,
    simular to a interact in a box i have been told
    Thanks for the help
    gus
    gus is offline
    Jan 2005
    us
    which control?
    later controls have a tool table soft key
    Aug 2009
    New Zealand
    Hi Gus,
    Have found that the older controls sometimes have a program 0 that is full of Tool Defs and referred to by all other programs. Do you know about this and whether the option is controlled by a parameter?
    DP
    Dec 2011
    Hungary
    TNC155 - TNC355
    MP225: central tool table
    - 0 = no central tool memory
    - 1...99 = central tool memory with number of tool stores
    TNC360 -
    MP7260 Number of tools in the tool table
    Input: 0 to 99
    - 0 = No central tool file
    - 1 - 99 number of tools, tool file is active
    iTNC530
    Input: 0 to 30 000
    Aug 2009
    New Zealand
    Nice one csg67,
    Mr rockers can now blow his new workmates away with that nugget, or alienate himself instantly, so might want to leave it for a couple of weeks before accidentally changing that parameter
    DP
    1. Easy part counting using tool offset page.
      By djc1965 in forum Haas Mills
      Last Post: 02-27-2012, 02:18 PM
    2. 412 interact tool page
      By windy in forum Bridgeport and Hardinge Mills
      Last Post: 04-20-2008, 03:54 PM
    3. Display Absolute on tool offset page
      By billm in forum Fanuc
      Last Post: 02-14-2007, 03:12 PM
    4. Arrow, Page Up & Page Down Keys - Rhino Video Tutorial
      By Robert Schutz in forum Rhino 3D
      Last Post: 04-25-2006, 11:09 AM
    5. NC reading tool length from offset page, not data page..?
      By RMagnusson in forum Mazak, Mitsubishi, Mazatrol
      Last Post: 03-21-2006, 05:07 PM
