Results 1 to 2 of 2
Thread: DRO on the Quill
    Nov 2007
    DRO on the Quill
    This is one of those things Newall don't tell customers about.... Or at least in my case I wasn't aware of it.
    When I installed the DRO on my little Bridgeport I couldn't use the original feed wheel for the quill. The wheel hit the mounting brackets and bolts for the encoder.
    I never knew how much I'd miss it.....
    I finally took the time to make a spacer to bring the feed wheel out almost 5/8 of an inch.
    So be ware of the problem. The only other option I know of is to use a smaller plastic wheel that comes on some of the imports.
    I left the drawing file at the shop so if some of you are interested, I'll post the drawing for the spacer tomorrow.....
    Aj
    Attached Thumbnails Attached Thumbnails DRO on the Quill-4450.jpg   DRO on the Quill-4451.jpg   DRO on the Quill-4452.jpg
    Nov 2007
    Just for grins, here it is....
    Aj
    Attached Files Attached Files
  1. Quill wobble
    By QSIMDO in forum Industrial Hobbies (Support forum)
    Last Post: 12-20-2010, 10:39 AM
  2. Tightening My Quill
    By Arich0908 in forum Benchtop Machines
    Last Post: 06-07-2010, 10:31 PM
  3. Syil SX3 Quill
    By Old Megawatts in forum Syil Products
    Last Post: 06-28-2008, 04:00 PM
  4. Powered Quill????
    By bill south in forum Mechanical Calculations/Engineering Design
    Last Post: 11-29-2006, 08:59 AM
  5. Quill removal
    By HOSS in forum Tree
    Last Post: 08-08-2006, 07:21 AM
