Results 1 to 4 of 4
Thread: can't remove heidenhain encoder
    Mar 2011
    brooklyn park, MN
    I can not seem to find out how in the heck to remove this encoder, it is off a bridgeport MDI. Anyone remove one before?
    Dec 2003
    Not removed the exact one but many Heidenhain shaft encoders, usually there is an access hole to allow removing the coupler set screw?
    The encoder shaft is still attached to the coupler, normally you don't need to remove the cover and circuit board?
    Mar 2011
    brooklyn park, MN
    Thank you, I had to turn the handwheel to see it, and boy what a small screw on that coupling.
    anyways, it looks like it is not threaded on the end, but might be able to run a tap in there, or possibly need to drill and tap it. Are these hardened steel, or should it tap fairly easily? Looking to put on AMT103 encoders and need a way to attach them.
    thanks again so much
    Dec 2003
    There may be enough shaft length to fit a AMT encoder, (.4")?
    Normally the shaft can be drilled and tapped, the problem is ensure no eccentricity.
  1. HEIDENHAIN ROD 271 ENCODER
    By CHANDRU in forum Bridgeport and Hardinge Mills
    Last Post: 05-30-2010, 07:45 AM
  2. Heidenhain encoder
    By N4NV in forum Servo Drives
    Last Post: 06-17-2009, 09:36 AM
  3. Problem- Heidenhain Encoder
    By Rupe in forum General Metal Working Machines
    Last Post: 12-09-2008, 04:04 AM
  4. Heidenhain encoder help
    By dave3431 in forum General Electronics Discussion
    Last Post: 10-06-2008, 05:45 PM
  5. Heidenhain encoder
    By N4NV in forum Gecko Drives
    Last Post: 02-10-2007, 11:24 AM
