brian257
I not quite sure what you are meaning, by hunting back driving
If you are using the machine in manual with hand wheels, then the power should not be on the motors
If you are using manual under power, then there should not be any movement from any axes, if they do you will have to tune the drives, No axes should move only if you give it a signal to move
When you turn the power on for CNC use the motors will/should lock up were ever they are, you then home the machine & you are ready to run
LinkBack URL
About LinkBacks
