Results 1 to 4 of 4
Thread: Bridgeport Interact 2 stepper motor needed.
    Apr 2009
    UK
    Hi
    The armature in my SEM stepper motor has burned out and i am having trouble locating a replacement.
    Does anyone in the UK who is doing an upgrade or breaking a series 2 Interact have a spare? I only need the windings so a dimantled motor would do me.
    It is a SEM MT30R4-58
    There is a possibility of a Fanuc motor which has similar part numbers maybe someone knows if the armatures are the same?
    Many thanks
    Mike
    May 2004
    United Kingdom
    Stepper or Servo?
    Mike, are you sure that is a stepper? I thought all the Interacts used servo motors, and havn't come across a SEM stepper.
    SEM are still in business in Bell Green south east London
    Andrew Mawson
    East Sussex, UK
    gus
    gus is offline
    Jan 2005
    us
    interacts have servos
    Apr 2009
    UK
    Doh
    Er... yes you are all correct. Sorry wrong terminology, it is a servo motor.
    Maybe it will make finding a replacement easier if i am using the correct name!
    Thank you.
  1. Need Help!- Bridgeport series 2 Interact 4 With Tnc 145 Parameters needed
    By Angoraracing in forum Bridgeport and Hardinge Mills
    Last Post: 03-01-2012, 10:52 AM
  2. Need Help!- Bridgeport Interact 412 CNC pump needed
    By TalonGrip in forum General Metal Working Machines
    Last Post: 09-03-2008, 06:53 PM
  3. Bridgeport Interact drive motor test - will this work?
    By swarf_rat in forum Bridgeport and Hardinge Mills
    Last Post: 03-09-2007, 06:11 PM
  4. Identifying Bridgeport Series 2 Interact 4 Spindle Motor
    By UKRobotics in forum Bridgeport and Hardinge Mills
    Last Post: 05-26-2006, 07:55 AM
  5. Advice Needed Regarding Bridgeport Interact Axis Motors
    Last Post: 02-09-2006, 05:45 PM
