Results 1 to 4 of 4
Thread: TNC145 Controller - Defunct (Nervous Breakdown)
    Mar 2012
    Wales
    Dear All,
    A friend has asked for help with his Bridgeport Interect II / Heidenhain TNC 145. The machine was purchased second hand about seven years ago by his father who refurbished it and installed a brand new TNC 145 controller.
    The machine operated satisfactorily up until his fathers sudden death a year later but has been lying idle since.
    Now when power is applied to the controller the CRT screen remains blank, the X,Y,X etc LEDs flash on and off and display random segments, all red lamps remain on and there is no response on depressing the CE button or indeed any buttons on the control panel.
    I have stripped and reassembled the control unit looking for any obvious signs of corrosion, component failure or chip creep without finding anything out of place. Indeed the contents of the controller look as if they left the factory yesterday. All connections to the back of the controller have also been checked and nothing appears out of place.
    Has anyone experienced a similar problem. Any help much appreciated.
    gus
    gus is offline
    Jan 2005
    us
    Well, they have not made brand new 145s in nearly 25 years, so it is at least that old.
    removing and reseating the cards is one option.
    Afraid Heidenhain no longer supports the control
    Jan 2011
    UK
    Smile
    Hi
    we have a couple of the old heidenhain machines 1 of which has 145 control, have you had the CRT checked to make sure it aint knackered or simply blown a fuse, worth a look, If you can remove the screen and talk to heidenhain UK they may be able to help as they have with us in the past, If it is just the crt that's had it it will cost approx £1000 to replace or refurb
    good look
    mick
    Nov 2006
    Scotland
    Better to give Heidenhain a miss.Your best bet of an economical repair is here..
    Bridgeport Machines, Heidenhain TNC Repair, Monitors, Terminals, CIMCO Software
    He`s ex Bridgeport service.
  1. Need Help!- Need help with pinout for VDU on heidenhain tnc145 controller
    By jbcj in forum General Electronics Discussion
    Last Post: 09-27-2011, 08:56 AM
  2. WA state designer nervous about CNC
    By lostgringo in forum Mentors & Apprentice Locator
    Last Post: 10-06-2010, 08:07 PM
  3. A little nervous of my CNC machine
    By darkling27 in forum WoodWorking
    Last Post: 09-13-2010, 03:45 PM
  4. Need Help!- Breakdown of woodwop mpr code
    By twoartistic in forum Commercial CNC Wood Routers
    Last Post: 08-17-2008, 10:57 AM
  5. Nervous about my electronics
    By yoopertool in forum Stepper Motors and Drives
    Last Post: 08-19-2007, 09:53 PM
