Results 1 to 2 of 2
Thread: Bridgeport series 2 Interact 4 With Tnc 145 Parameters needed
    Feb 2012
    Denmark
    Hey All
    I bought a Bridgeport series 2 Interact 4 With Tnc 145 but it lost its parameters, I have been searching this forum and have just came up with parameters for the interact 3.
    But can I use the parameters from that one, or can anybody help me with a link or the parameters.
    Here are the parameters I found in here.
    And what about a manuel for the Bridgeport series 2 Interact 4 does anyone have that?
    Thx
    Christian Ulberg
    Attached Thumbnails Attached Thumbnails Bridgeport series 2 Interact 4 With Tnc 145 Parameters needed-tnc145c_int1_2.pdf
    Attached Files Attached Files
    gus
    gus is offline
    Jan 2005
    us
    Interacts do a few things differently than the r2c3, for instance y homes out on an interact and in on an r2c3. Series 2 may have different things than series one, so if you find a s2 interact it should get you close. If it is not already in the heidenhain parameter thread, and you find it, post it there
  1. Bridgeport Interact 520/Heidenhain TNC 155 initial parameters
    By jeromir in forum Bridgeport and Hardinge Mills
    Last Post: 05-16-2013, 01:03 PM
  2. Need Help!- bridgeport interact 1 lost parameters
    By thomasmc in forum Bridgeport and Hardinge Mills
    Last Post: 03-29-2012, 01:44 AM
  3. Bridgeport Interact 720VMC auto lube parameters
    By FLjoyride in forum Bridgeport and Hardinge Mills
    Last Post: 07-06-2011, 12:46 AM
  4. Need Help!- Bridgeport Interact 720 parameters
    By M.G.Machinist in forum Bridgeport and Hardinge Mills
    Last Post: 01-07-2010, 07:04 PM
  5. Bridgeport Interact 412/Heidenhain TNC 250 initial parameters
    By pedrow in forum Bridgeport and Hardinge Mills
    Last Post: 04-04-2007, 01:09 AM
