Results 1 to 2 of 2
Thread: RS232 Bridgeport Boss 5
    ops
    ops is offline
    Aug 2005
    Hello,
    I need help for my BP Boss 5, I made an accident when hook up to power source, 1 of hot wire switch to ground wire, then I reconnect property,RS232 not working, any other functions work well.
    Now I could not transfer program from PC to machine. Type manual too hard.
    Anyone Help, Please.
    Thank you very much
    Nov 2011
    I have found while troubleshooting my son's Bridgeport Series I CNC that a weak link in the RS-232 communications system is the Line Driver and Line Receiver ICs on the ERS CCA (IC4 and IC9). These chips are easily damaged if you have an inadequate ground between the CNC and external computer. If you have an oscilloscope, you can trace the RS-232 signal on the ERS CCA. Convenient test points are provided. These chips are fairly easy to change since they are Dual In Line (DIP) packages.
    Good luck,
    Rick
  1. Need Help!- boss 8 rs232 cable
    By dougputt in forum Bridgeport and Hardinge Mills
    Last Post: 02-14-2012, 10:01 PM
  2. Need Help!- RS232 COMMUNICATIONS FOR BRIDGEPORT TNC 155
    By jayshinde2010 in forum Benchtop Machines
    Last Post: 03-05-2011, 03:45 PM
  3. tncRemo RS232 and Bridgeport Interact 2
    By Shanghyd in forum Bridgeport and Hardinge Mills
    Last Post: 08-05-2010, 12:57 AM
  4. Boss nine rs232 problems
    By Plateroom in forum Bridgeport and Hardinge Mills
    Last Post: 09-20-2008, 06:29 AM
  5. Bridgeport R2E3 RS232 Cable Adaptor ???
    By JLSEYLAR in forum Bridgeport and Hardinge Mills
    Last Post: 04-29-2007, 12:09 PM
