Results 1 to 5 of 5
Thread: Is the DX32 Software for V2XT and Torq-Cut 30 the Same?
    Aug 2010
    I have a V2XT that was one of the last made. I recently purchased a Torq-Cut 30 from around the 1997 era. I have the DX32 backup disks for the V2XT but not sure if I will be getting the backup disks for the Torq-Cut. Will the DX32 back-up disk for the V2XT work for the Torq-cut as long as i have a backup copy of the Torq-cut's BMDCPRMS.SYS parameters file?
    Thanks for any info
    Moderator
    Nov 2004
    I do not think so. Too many differences in the internals (drives, etc).
    I do not recall seeing a software disk that covered both.
    George
    Aug 2010
    I was hoping that wasn't the case. To pick your brain, what years were the TC22 and TC30 made? It seems like not too long before Bridgeport switched to the nomenclature of TC1, TC2, 3 and 4. Was it the notorious lawsuit that made them switch?
    Moderator
    Nov 2004
    The lawsuit was due due to the inability of the DX32 control to do 3D work. The BMDC did not really have a fast processor. Bridgeport come out with a BMDC4 which had more memory and a faster processor. Bart Stater also modified the algorithms for acceleration and deceleration and modified the Siemens tuning cards in the Siemens drives for a great improvement in 3D machining on the vertical machining centers like the 760.800 and 1000.
    The Tc22 and 30 use DC motors and these use brushes. These were getting dated. So Bridgeport had to keep up with the competition and they switched to Yaskawa drives and brushless motors. Thus the TC1 etc. Also built with a Fanuc control.
    I have to check my records to see when I installed the last V2XT.
    George
    Aug 2010
    George,
    Once again thanks for the info.
    1. dx32 torq cut 22 software
      By holmes9921 in forum Bridgeport and Hardinge Mills
      Last Post: 08-07-2011, 12:16 PM
    2. Need Help!- DX32 torq-cut 22 software needed.
      By JohnMckenzie in forum Bridgeport and Hardinge Mills
      Last Post: 12-30-2009, 08:11 PM
    3. Need Help!- Torq Cut 4 with DX32 postprocessor
      By emvali in forum Bridgeport and Hardinge Mills
      Last Post: 08-05-2008, 03:13 PM
    4. Torq-Cut 22 DX32 Dripfeed?
      By OC_ in forum Bridgeport and Hardinge Mills
      Last Post: 03-03-2008, 07:52 PM
    5. DX32 questions (Bridgeport Torq Cut 22, DX-32, DX 32)
      By vettespeed in forum Bridgeport and Hardinge Mills
      Last Post: 02-03-2007, 04:14 PM
