Results 1 to 4 of 4
Thread: Tall CNC-File
    Nov 2005
    Germany
    Tall CNC-File
    I am using a BP Eztrak 2 CNC . I create a g-code file with 500 kB , when i want to load the file into the machine i always get the message buffer overflow .Files with 100kB can i load . In what kind of way i can use the tall file ?
    Many thanks for every answer
    Hans
    Nov 2004
    Drip feed? I don't know about that controller but with my TNC151 I can drip feed a large file.
    I transfered files but have never used the drip feed feature.
    Feb 2005
    Drip Feed to EZtrak
    You can drip feed from floppy or hard drive. I posted some pictures on this several years ago. Check out this thread it may help you. The maximum file size you can run without drip feeding is 256K.
    Older Bridgeport with outdated cpu
    Moderator
    Nov 2004
    Only the 3 axis EZTRAK has the ability to DNC. The reason for the buffer overflow is that you load a file to the BMDC which has a finite memory.
    I believe that you generated a program with a CAD system. They stitch together a program in blocks and there is a lot of extra lines of code. Have you tried to write the same program using the conversational side of the machine?
    George
  1. Growing tall
    By CNCadmin in forum EnRoute
    Last Post: 10-20-2011, 02:50 AM
  2. Bridgeport series 2 too tall to get in the garage
    By Shanghyd in forum Bridgeport and Hardinge Mills
    Last Post: 08-15-2011, 10:37 PM
  3. How tall Celing for a 4020 VMC fadal
    By kojack in forum Fadal
    Last Post: 11-17-2007, 01:06 AM
  4. Tall vmc - Low doorway
    By rlevin in forum General Metal Working Machines
    Last Post: 08-30-2006, 07:16 PM
  5. How tall is too tall ?
    By samualt in forum DIY CNC Router Table Machines
    Last Post: 07-28-2004, 12:53 PM
