Results 1 to 2 of 2
Thread: Bridgeport Interact Series 1 mk 2 w TNC151b control
    Jan 2012
    UK
    Hi
    I have an interact series 1 mk 2 with heidenhain TNC151b control. I have just this morning started to test it with some ureol to check it is all in order before i launch it into active service
    Unfortunately there seems to be an issue with calibration or similar.
    I programmed it to cut a cube 85mm (using 16mm tool) in the X and Y and the depth of the block (45mm). However the end result is only 83.7 in the X and Y.
    After sometrial and error this morning have found the following
    If my code says start at 0 and move to 101 across the X the tool actually only moves 99.3 (hence the smaller square).
    If I then use the wheel to manually move the tool back to the 0 position it goes further than original 0 start point to leave a gap of 1.3mm between the tool edge and the original cut.
    any ideas, is this something i can fix or do i need an engineer to calibrate if, if so, anyone know a good one in the south east / east of england?
    thanks
    Gavin
    gus
    gus is offline
    Jan 2005
    us
    Hmmmmm
    possibly backlash parameter set too high?
    Does the machine run smoothly even when at rapid?
  1. Need Help!- bridgeport series 2 interact 4
    By dcchip in forum Bridgeport and Hardinge Mills
    Last Post: 04-30-2010, 08:27 PM
  2. Bridgeport Series 2 Interact 4 CNC Control Parts
    By Gnome in forum Bridgeport and Hardinge Mills
    Last Post: 03-28-2010, 08:53 AM
  3. Need Help!- Mach 3 control on Bridgeport Series 2 Interact 2 CNC
    By PeeBee in forum Bridgeport and Hardinge Mills
    Last Post: 09-22-2009, 10:23 PM
  4. bridgeport interact Tnc151B plc
    By hansdie in forum Bridgeport and Hardinge Mills
    Last Post: 01-12-2009, 04:44 PM
  5. bridgeport series 11 interact 11 hiedenhain tnc 2500 control
    By blackpalm in forum Bridgeport and Hardinge Mills
    Last Post: 09-20-2007, 12:21 AM
