Results 1 to 3 of 3
Thread: Bridgeport 760/20 X-Axis seimens servo motor hunting/ giving vibration during run
    Oct 2010
    India
    Angry Bridgeport 760/20 X-Axis seimens servo motor hunting/ giving vibration during run
    Hi everyone...
    In our bridgeport 760-20, Heidenhain 2500 B with seimens drvies, X-Axis is giving excessive vibration during runing....
    When the machine is run on full feed then machine shows, GROSS POSITIONING ALARM, sometimes A, B or sometimes C.
    but when feed rate is less than 50%, it X-Axis runs but with vibration from the motor...
    Please help.......
    Moderator
    Nov 2004
    I have seen 2 reasons for this. The hall effect triggering transistors inside the motor are misfiring. In the second case I had a defective cable that was arcing to the ground wire in the cable. In this second case the machine shook so bad in the Y axis, I thought it would start moving the machine. My meter could not find this using the ohms setting. I cut the cable open to find it. That after replacing everything else. It was a new install.
    George
    Oct 2010
    India
    thanks machinetek for reply.....
    I have already tried replacing the encoder cable which goes to siemens drive but hadn't replaced the Cable going to LT unit...
    can you tell me which cable you are talking about...?
    1. Motor encoder to Siemens drive or encoder cable to LT unit or Power cable..?
    2. If in 1st case as told misfiring than motor has to be replaced?
    Please reply...
  1. Need Help!- Z Axis Hunting?
    By BTCAT40 in forum Bridgeport and Hardinge Mills
    Last Post: 05-20-2013, 10:41 AM
  2. Need Help!- Bridgeport XR1000 w/Fanuc 18i-MB giving 2063 alarm
    By handy223 in forum Bridgeport and Hardinge Mills
    Last Post: 04-05-2011, 08:58 AM
  3. Need Help!- 1HP motor with delta vfd giving very poor torque
    By jasminder in forum Phase Converters and VFD
    Last Post: 12-28-2010, 07:31 PM
  4. Need Help!- Dismantling of Encoder from Seimens Servo Motor
    By wahidbashir in forum Bridgeport and Hardinge Mills
    Last Post: 10-16-2010, 05:05 PM
  5. servo motor vibration
    By tkh60 in forum Plasma, EDM and other similar machine Project Log
    Last Post: 05-09-2007, 03:47 PM
