Results 1 to 7 of 7
Thread: boss 8 rs232 cable
    Aug 2007
    canada
    boss 8 rs232 cable
    Can anyone please help me with the pinouts for a Boss 8 RS232 to AMP connector.
    I cannot get nclink to talk to my machine. I have a cable for a Boss 5 but I believe pinouts are different
    Oct 2006
    canada
    i am sure i read a post by machinetek where he gave the pinout for boss 8 &9
    Aug 2007
    canada
    thanks LB
    John B sent me the correct pinouts,
    "The cable to port B is just using three wires, depending if you are using a DB9 or DB25 . I’ll assume you are going to use a DB9, so the cable should be DB9-2 to AMP 8 (transmit), DB9 -3 to AMP 6 (receive) and DB9 – 5 to AMP 7 (signal ground) "
    Moderator
    Nov 2004
    FYI: Boss 5 can do 20ma current loop to a teletype. This requires 4 wires and a shield.
    Or can do RS232 which requires 3 wires as mentioned and a shield. Note that shield is only connected at one end.
    George
    Oct 2006
    canada
    Hey George, quick question for ya
    How long does a boss8 auto lube run for? I want to retain the auto lube function and must connect it to a timer. The manual says it comes on around every 30 mins
    Moderator
    Nov 2004
    On all the BOSS machines with the BIJUR, the motor in the unit runs whenever the spindle is turning. It is geared, and runs a cam that lifts and drops a plunger to give a shot of way oil about every 20 minutes. The stroke of the plunger is variable to adjust the oil output. The TC22 has the same arrangement. But the VMC machines do use timers for pump On and OFF. Those are not BIJUR units.
    George
    Oct 2006
    canada
    as always your reply is appreciated!
    cheers
    1. Need Help!- RS232 CABLE FOR MILLTRONICS C7
      By VBUZZ in forum Milltronics
      Last Post: 09-16-2011, 10:24 AM
    2. Need Help!- rs232 cable
      By Mazaman in forum Mazak, Mitsubishi, Mazatrol
      Last Post: 03-01-2010, 05:28 AM
    3. Need Help!- RS232 cable
      By Zep in forum Machine Problems, Solutions , Wireless DNC, serial port
      Last Post: 09-05-2008, 09:46 AM
    4. rs232 cable
      By Dar in forum Bridgeport and Hardinge Mills
      Last Post: 12-13-2007, 01:51 AM
    5. Fanuc om-d rs232 cable
      By Julian M in forum Fanuc
      Last Post: 09-09-2006, 07:41 AM
