IF the wild leg of your converter is trying to run the control, this might happen.
Hi all
I real need some help with this machine
Bridgport seris 1 interact with air extras for motor speed and break. I think I have the correct wiring diagram.
Heidenhain TNC 145 CS
Running of 10 HP converter with a 5hp idle motor to give a smooth supply.
Spindle motor runs great
I have checked most of the obvious things but am now stuck
When I switch on the screen displays correctly with the refersnce ZYX message
No error lights
The oil is fine and float switch OK
When I press the power enable button there is a click from the control box and then the power drops out and we are back to "power interupt" screen
I guess one of the relays is faulty or there could be a short somewhere, which relay would it be?, Can anyone give me some ideas where to look.
The Z axis is on its top limit switch
No its not that I swaped it round to rule that out, shouldnt be an issue with an idle motor in line.
380 to 410 volts on the phases
I started a new thread to get advice on updating the control system if I have to go down that route. There seems to be a welth of experiance on updating bridgeports and I dont want to make a hash of it or waste money that is scarce for me
