| Not a fair question. Need to know which TNC control. I also had problems doing label calls because so of the older controls did not recognize the decimal point. George
| I have a Bridgeport Series II Interact 4 with a Heidenhain TNC 2500 controller. I just get bugged by the use of the European use of the comma as a divider for the difference between the intergers and the decimal part of the number. I found the parameter to change it on my Interact I Mk2 wit a Heidenhain TNC 151, But the parameter list looks totally different for the 2500. Do you need to know the software serial number? |
| The TNC 2500 has a totally different set of parameters from the 151 control. Not only that but there is a difference with which level of software you have. Originally the 2500 came with version 3. Eventually BPT settled on version 12 (done by ROM) change. I have a service manual for this control and will have to get by the office to look this up. George
I have the NC: software number 243000 12 . The PLC: software number 250144 10 .I have a list of all the parameters and their values, but I would like also to find a synopsis of what each parameter controls. Such as one parameter may change the control to a foreign language. And such...Thanks, Dan |
| Dan, http://filebase.heidenhain.de/doku/o...CE/N14ACE.html Has the technical ref manual. That should have a list of all the parms and what they do. I grabed the 151 version when I was debugging my MK2 and it helped quite a bit. Paul |
| Per the Heidenhain web site manual it is parameter 7280. Thank you. While available, I will download quite a bit of this site! George
#10
| Dear Sir, From the forum I have understood that you have: NC 243009 12 PLC 250144 03 Which are used for Heidenhain TNC 2500 Actually, I have a problem with my machine, and I need these parameters, so, how can I obtain them from you? Thanks for your kind attention. Mahmoud Elhosseiny Egypt E-mail: mahmoudelhosseiny@yahoo.com |
#12
Thanks for replay. My address is: Borai Group 79 Sudan street Dokki - Giza Egypt Mobile Phone: +20-12-3066980 E-mail: mahmoudelhosseiny@yahoo.com My Machine details are: Bridgeport Series II Intract 4 Control: Heidenhain TNC 2500 Serial No.: 616901290E/04881 I have lost the machine Parameter, and also I need: - Machine Parameter - NC 243009 12 - PPLC 250144 03 Thasnk you very much for your kind attention & waiting for your replay. Best regards Mahmoud Elhosseiny |
