Results 1 to 5 of 5
Thread: Boss 5 spindle interlock with HillBilly BOB
    Aug 2007
    canada
    Hi
    Retrofitting another Boss 5 machine with Darek's great HillBilly BOB, but I can't seem to get spindle to start unless I pull the fuse from output 14 on the BOB.
    Yes, weighlube is full. Machine runs fine when I pull that fuse, I have added the M3 M5 macros and macropump, restarted the program etc.
    On my last retro I think I added another Control relay to control the spindle, but I can't remember, should have taken notes
    Sep 2011
    I don't know about the Hillbilly BOB, or output 14, but Bridgeport lead 203 needs to go "open" to allow the spindle to run, via CR3; low (ground) equals spindle off.
    Lead 204 goes high (+24V) when the spindle is running, and is what I connected to the block allow.
    Lead 211 needs to be jumpered to lead 214, if CR1 has been deleted (as well as the limit over-ride switch)
    All lead numbers are from the terminal strip at the bottom of the BP power cabinet.
    Aug 2007
    canada
    Thanks Scottly
    seems as though I had a issue with the BOB. pulled the fuse and spindle would work.
    Sep 2011
    Can you reverse the polarity of output 14 in the control setup? (I'm using an AHHA control, and the input and output polarities of each lead can be changed from high=true to low =true.) I wired the normally closed contacts of a relay to lead 203 and ground. When I call out an M3, the relay operates and opens the contacts, allowing the spindle to start. Maybe your BOB is set up to only allow the spindle to start when the relay is not operated, which is why it works when you pull the fuse? Just guessing here...
    I would measure the voltage on lead 203, both with an M3 and an M5.
    Aug 2007
    canada
    I have it working properly now. What I ended up doing was still using output 14 on BOB to control spindle, but I added a small relay to control the signal further downstream, which is coming from the old K6 pins 6 & 7.
    1. Need Help!- sub spindle interlock
      By hacdlux in forum Mori lathes
      Last Post: 06-02-2010, 03:19 AM
    2. few questions about Boss 4 retro with HillBilly BOB
      By TbcSEOD in forum Bridgeport and Hardinge Mills
      Last Post: 04-11-2010, 09:08 AM
    3. boss 5 / mach3 hillbilly bob z limit home
      By tom.jelly in forum Bridgeport and Hardinge Mills
      Last Post: 10-30-2008, 03:26 PM
    4. hillbilly board
      By valmet58 in forum Want To Buy...Need help!
      Last Post: 07-27-2008, 07:24 PM
    5. Mach 3 with HillBilly BOB
      By tpmx57 in forum Bridgeport and Hardinge Mills
      Last Post: 04-14-2008, 09:19 PM
