Old 02-02-2012, 12:26 PM
kosmo is on a distinguished road
Gecko 203V Bridgeport stepper wiring
Looking for BP stepper motor parallel wiring schematic with phase connection to G203V drives. Been lurking awhile, haven't found a straight forward diagram. Thank You
Old 02-03-2012, 10:59 PM
scottly is on a distinguished road
Which motors do you have? The Superiors or the Sigmas?
Old 02-03-2012, 11:05 PM
I have the Sigma motors
Old 02-04-2012, 06:37 PM
Connect motor terminals 1&5 to /A
Connect motor terminals 3&6 to A
Connect motor terminals 2&7 to /B
Connect motor terminals 4&8 to B
(If the motor runs in the wrong direction, switch the A and /A leads)
Old 02-08-2012, 08:12 PM
Thanks! I actually found this setup on another post but was looking for clarification. Would this be a parallel wiring ?
Old 02-08-2012, 08:22 PM
Yes, this would be a parallel connection: the coil with leads 5&3 is in parallel with the coil with leads 6&1, and the coil with leads 7&4 is in parallel with the coil with leads 8&2.
Old 02-09-2012, 09:11 AM
Myk Bates is on a distinguished road
I am also using my old bridgeport steppers and Gecko 203V's. How can you the differance between Sigma and Superior motors? Is the wiring that different?
Thanks for the Help.
So many projects, so little time...
Old 02-09-2012, 10:01 AM
The terminals on the end of the motors are arranged differently; this makes it easy to tell the difference. The attached pics are scanned from the BP wiring diagram.
Old 02-09-2012, 10:04 AM
oops!
ID:	152339   Click image for larger version
Old 02-09-2012, 09:47 PM
Wow! Good fast information. Thanks for the reply scottly.
  #11   Ban this user!
Old 02-09-2012, 10:11 PM
You're welcome! If you have the superior motors, I do have some info on parallel bi-polar wiring, but I have not verified it. It is completely different from the sigma wiring.
  #12   Ban this user!
Old 02-09-2012, 10:19 PM
I keep reading about parallel and series wiring but I dont know enough to know why you would do one and not the other. Does it matter? Is there a place on cnczone that explains this more. I dont want to hijack this thread.
Need Help!- 203V and bridgeport stepper wiring kosmo Gecko Drives 4 02-13-2012 05:55 PM
Will 203V Gecko drive control a Boss 3 stepper motor jbrant Bridgeport and Hardinge Mills 9 12-18-2010 06:55 PM
Need Help!- Wiring a C11g Board and Gecko 203v for lathe adbradley Stepper Motors and Drives 7 11-09-2009 11:49 AM
Need Help!- gecko 203v won't turn my stepper benjamint76 Gecko Drives 1 07-27-2008 01:47 PM
Wiring an 8 lead stepper to a Gecko 201 ChrisJ Gecko Drives 15 05-02-2005 02:15 PM
