Hello, I have a new MTI-1 card and new motor installed when I do a tool change m25 or m6 machine cutts off then when I go to start back up the MTI-1 card will not come back on with out me pully one of the fuses out on the board has anybody had this problem? Thanks |
| What does "cut off" mean? The panel circuit breaker trips? The breaker (CB1) in the spindle cabinet trips? Only on M6 and M25? Does the spindle start and stop normally if you use M03/04 and M05? I think to get specific advice you will need to give more specific decryptions of your conditions and symptoms. Mark |
| The MTI-1 board works perfect with m3,m4,m5 command but after you call m6 or m25 after the quill retracts and the spindle cuts off for you to do a tool change when you go to start the machine back up you get a spindle error the only way to get the machine back running I have to remove one of the fuses from the MTI-1 board to get it back on. |
| Bridgeport CNC Series 1 vs Series 2 | jshank | Bridgeport and Hardinge Mills | 27 | 05-26-2012 08:51 AM |
| Multicam 3000 Series vs AXYZ 5000 Series | adamfilip | Commercial CNC Wood Routers | 1 | 10-18-2010 02:54 AM |
| Series 2 cnc 2 hp motor on a series 1 bridgeport? | CATCH22 | Bridgeport and Hardinge Mills | 1 | 11-08-2008 08:18 AM |
| What is the Difference between 6000 series aluminium and 7000 series | Kosta1234 | General Material Machining Solutions | 3 | 11-19-2005 08:04 AM |
