Results 1 to 2 of 2
Thread: Converting Bridgeport to CNC
    Registered nokillzone's Avatar
    Oct 2008
    canada
    Post Converting Bridgeport to CNC
    What Motors to use .. on a 10x54 table
    Nema 34 878oz
    or
    Nama 34 1600oz
    Use the 1600 for table and 878oz for quill OR WOULD 878oz work for all axis ?
    Can someone Let me know Before i spend Money...
    Thanks!
    May 2008
    Here is what I did form my BP conversion which seems to work super:
    Current Mill Drive Setup:
    X,Y axis (5 TPI 1.25" dia. gorund ball screws)
    Tormach 1558 in-oz Stepper motor
    Drive configuration: (2:1 28 tooth and 56 tooth pulley
    SPD/SI A 6A25M028DF1508 HTD 5mm pitch (28 tooth)
    SPD/SI A 6A25M056NF1512 HTD 5mm pitch (56 tooth)
    SPD/SI A 6R25M133150 15mm wide 133 teeth timing belt
    SPD/SI A 6R25M117150 15mm wide 117 teeth timing belt
    Knee: (5 TPI 1.5" dia. ground ball screw)
    Kelinginc.net KL342160-62-8A (1810 in-oz) Stepper
    Drive configuration: (3:1 24 tooth and 72 tooth pulley)
    SPD/SI A 6A25-024NF1508 HTD 5mm pitch
    SPD/SI A 6A25-072NF1512 HTD 5mm pitch
    SPD/SI A 6R25M133150 133 teeth 15 mm wide belt
    Quill: kelinginc.net KL34H295-43-8B (906 in-oz) Stepper Motor
    SPD/SI
    Drive configuration: timing belt 2:1
    Steper Drivers: Gecko 203V's about 65V
    Craig
  1. Converting Bridgeport 408v to 208v?
    By MechanoMan in forum Bridgeport and Hardinge Mills
    Last Post: 11-06-2011, 03:27 PM
  2. converting N.m to oz-in
    By eloid in forum DIY CNC Router Table Machines
    Last Post: 08-11-2011, 10:18 PM
  3. Converting to +/-10v Possible?
    By simonrafferty in forum Gecko Drives
    Last Post: 04-07-2010, 09:30 AM
  4. Need Help!- converting to dxf
    By charles38242 in forum General CAM Discussion
    Last Post: 05-22-2009, 10:10 AM
  5. New Machine Build- Couple of questions on converting a bridgeport to cnc
    By jawsoflife in forum Bridgeport and Hardinge Mills
    Last Post: 03-09-2008, 08:31 AM
