Page 2 of 2 FirstFirst 12
Results 13 to 17 of 17
Thread: r2e3 X AXIS MARKER
  1. #13
    Apr 2005
    DLI board
    I believe that that stands for " Don't Look for Intelligence" as this I believe should have been written on the diagram as ELI board (I notice that there were over 7 revisions and no one noticed). The ELI board is in rear cabinet next to the radio knobs (backlash adjustment) just above PS2
    Attached Files Attached Files
  2. #14
    Aug 2007
    canada
    Ok, checked all wiring between encoder, servo and FMDC board, ELI board and servo drives. All checked ok.
    I suspect maybe a IC on the FMDC board, will try swapping some chips between another axis.....wish me luck.
    I noticed there is one jumper connection missing on the FMDC board. Not sure if it should be there will post pic later
  3. #15
    Aug 2007
    canada
    Ok, so TB 8 is missing a jumper on FMDC board. will look up in a bit
  4. #16
    Aug 2007
    canada
    Sorry I meant TP 8 not TB 8 on FMDC
    Anyone know what it's for?
  • #17
    Aug 2007
    canada
    Exclamation Drift on drives?
    Thanks George, tachs go to drive boards and also tee off to ELI board.
    If you were to venture a guess would you suspect encoder fault or tach gen fault? So the tach gen supplies power feedback to drive? Marker pulse would give?
    Regards
    Doug
    Quote Originally Posted by machintek View Post
    That is Hex for the distance. The 0001 indicates the X axis.
    Have you ohmed out the cable?
    I remember that the encoders go to the FMDC. I used to pull the connector on each axis to set the drift (balance) on the axis drive boards. If I was to venture a guess, the tachs also go to the axis drive boards. Have to find a set of prints. It has been a while.
    George
  • Page 2 of 2 FirstFirst 12
    1. R2E3 z axis travels
      By dougputt in forum Bridgeport/Romi Lathes
      Last Post: 02-25-2012, 11:50 PM
    2. Replies: 4
      Last Post: 12-02-2010, 06:37 AM
    3. Need Help!- loat Y axis marker
      By BrianP in forum HURCO
      Last Post: 10-19-2010, 07:04 PM
    4. R2E3 X-Axis problem
      By Jadaan27 in forum Bridgeport and Hardinge Mills
      Last Post: 09-06-2007, 08:18 PM
    5. Z axis going nuts on my R2E3
      By Creative Tool in forum Stepper Motors and Drives
      Last Post: 06-09-2006, 12:37 AM
