Well after hooking up the FIST cable to K3 on FMDC and with John's help figuring out the comm FIFO and Baud rates, at least it is readable info coming up on TeraTerm, but I still can't get any info other than what I posted below in wrong forum... ![]() This is what it comes up with after the usual Bridgeport 1983....blah, blah, blah after the line type "H" for help it shows this !06B0 !05AC !126E !0DAC |
| Due to a more recent post, I can assume fist is readable? I use a DOS version of PROCOMM. Believe it is closely related to what you are using. For anyone else searching, would you like to post the solution to your particular difficulty? George
| Hi George Yes the FIST is working now. John B has helped me by looking at his cabling at the K3 end. The issue was DB9 pin 5 to K3 pin 2, I had it going to K3 Pin 9 Other pinouts are DB9 pin 1 to K3 pin 3, DB9 pin 2 to K3 pin 3 Thanks for everyones continued help!! |
| R2E3 FIST | dougputt | Bridgeport/Romi Lathes | 5 | 01-19-2012 05:14 PM |
| Need Help!- Series1 R2E3 problem | snovak240 | Bridgeport and Hardinge Mills | 4 | 05-28-2011 10:52 AM |
| Need Help!- Need help with R2E3 problem. | Revshift | Bridgeport and Hardinge Mills | 27 | 12-02-2010 11:14 AM |
| Bridgeport R2E3 "Fist" monitor cable | John Bennett | Bridgeport and Hardinge Mills | 0 | 06-26-2009 03:18 PM |
| R2E3 X-Axis problem | Jadaan27 | Bridgeport and Hardinge Mills | 1 | 09-06-2007 07:18 PM |
