Wow, talk about gremlins… This sucker may have had power spike or other…I don’t know. Got through the ADC error, and now I have “X Axis High Voltage is Low”. There is around 96Volts (from T2) coming into the capacitor assembly labeled “135 Volt Power Supply” which appears to feed the Axis control boards. The ac is 96 Volts on the way in and does not come out. No power out of the “135V Power Supply”. It looks like the Power Supply assembly consists of (2) diodes and a large blue capacitor. Part Num Cornell Dubilier DCMX153T200DF2B……15,000uF 200VDC Anyone know for a Torqcut 22, what the correct input and out voltages would be on the Power Supply feeding the Axis control boards?? Looking for a Torqcut 22 Controller manual on PDF. Thanks, CD |
| For future benefit. This was a very simple fix, but easily over looked. We replaced 5 amp fuses with 5amp fuses, but they blew instantly and we did not know. So, we looked a little closer and realized that 5amp fuses was certainly not enough for this circuit when 2 or more motors are pulling. First, we checked for shorts, etc. Then disconnected the outbound power and one by one reconnected everything, each time checking the power supply. All looks good. We put in 20amp fuses and they held. I believe the 20amp fuses are still lighter that what BP specs for this power supply. We are using the fuse specification on the Torq-cut 22 wiring schematic. Thanks, CD |
| Tags |
| x axis high voltage low |
| "low end" HF Spindle or "high end" router for about $1000? | biomed_eng | DIY-CNC Router Table Machines | 14 | 01-06-2012 12:15 AM |
| "X" axis ballscrew locking up at high speed | Barefootboy4 | Linear and Rotary Motion | 42 | 07-19-2011 01:55 PM |
| Okuma's misteryous "Y" axis error | ungie | Okuma | 6 | 01-31-2011 02:03 AM |
| Need Help!- Fanuc 11m Spindle drive code 11: "DC Link Voltage High" | cwtoyota | Fanuc | 2 | 04-09-2010 10:56 AM |
| Need Help!- Multicam 3000 Error: "Warning Low Voltage (4.89VDC 0.00 VAC) | lukaspanic | Commercial CNC Wood Routers | 2 | 05-13-2009 08:43 PM |
