Old 01-13-2012, 05:04 PM
jmccracken is on a distinguished road
Bridgeport Interact w/ Heidenhain 151 - "tornado" cutting is slow
Hi all ... I was doing what some call a "tornado" pocket or drill procedure whereby the endmill describes a spiral thus creating a hole. Thus its doing G02 moves in X, Y, and Z simultaneous motion. My problem is that its a bit jerky in that it does a line or two of code, has a noticable pause, and then does another line or two of code.
Is this a phenomenom related to processor speed or is there some way to make it move smoothly, without stopping? Is this something I just need to live with understanding I have an antique (but quite functional) controller?
I'm using CamBam to make the post ... perhaps there is some sort of parameter that could help?
Thanks!
Old 01-14-2012, 06:31 AM
gus gus is offline
gus is on a distinguished road
All I know is that in conversational it takes ~4 lines of code to make such a move
CC
IX .5 F100
CP IA720 Z-1 F100
Z.5 F2000
syntax is not correct since I just whipped it out of my head, but there would be no pauses
Your pauses are either because it is trying to stop at corners, or your drip feeding or possibly machine setup
Bridgeport Interact 1 MkII "Gross Positioning Error D" tomcannon Bridgeport and Hardinge Mills 1 08-11-2011 08:15 AM
What encoders would you recommend for "Bridgeport Series II Interact 2" CNC conversio ichudov Bridgeport and Hardinge Mills 1 06-07-2010 04:53 PM
Weight of "Bridgeport Series II Interact 2" milling machine ichudov Bridgeport and Hardinge Mills 3 03-23-2010 04:21 PM
"Gross Postioning Error A" Doing M03 on Bridgeport Interact Series 1 Mk2 MeTri Bridgeport and Hardinge Mills 5 12-27-2009 11:37 PM
Newbie- How do I "Traverse Axis"? Bridgeport Interact 1 Mk2 TNC 155 MeTri Bridgeport and Hardinge Mills 5 12-27-2009 05:10 PM
