I'm probably going to convert a benchtop mill, but if I end up where I have a garage after I get moved, I'd like to pick up a Bridgeport for the larger non-CNC jobs... But I'd eventually like to convert it too... I'm going to be making predominantly smaller parts for a niche market or two, but having a big mill would just be convenient... If I don't have to replace ball screws, stuff would be significantly more simplified. Eventual CNC conversion will likely involve a fourth axis running off a Mach3 controller, since I've seen how difficult things get in keeping older machinery/controller electronics running. Any hints/pointers? I use a Jet 9x42 and a BP 9x42 daily for manual stuff... |
| "If I don't have to replace ball screws, stuff would be significantly more simplified." You most likely will not find a manual mill with ball screws. However they are easy to spot if you actually look at the screw. Standard screws use acme threads, and ball screws have rounded grooved thread for the balls to engage in. They feel WAY different when you turn the handle too. Clay |
| For sale: 2 ball screws, 2 ball nuts 2 fixed end bearing blocks and bearinsgs. | hub | EBAY ADS | 0 | 09-21-2011 01:08 PM |
| ball screws | morbius | Bridgeport and Hardinge Mills | 2 | 06-05-2007 03:37 PM |
| ball screws | skeezy | Linear and Rotary Motion | 0 | 05-15-2007 01:45 PM |
| Ball screws, Acme screws, threaded rod | DJ Morrow | DIY-CNC Router Table Machines | 11 | 03-22-2007 12:39 PM |
| Which Ball Screws to use? | Willyb | Linear and Rotary Motion | 4 | 01-19-2005 08:49 PM |
