Results 1 to 4 of 4
Thread: EZ-Trak boot up problem
    Registered HawkJET's Avatar
    Mar 2009
    I have a friend with an EZ-Trak DX and he can only boot up with a floppy. My guess is that the boot directory on the hard disk is corrupt because the machine runs fine after boot from the floppy. I suppose it is possible that the hard disk in inoperable.
    Does anyone have suggestions?
    A general overview would be great to know. For instance:
    What OS is used?
    Where are files available (if needed)?
    Can any computer be used?
    Is there a proprietary Bridgeport board in the computer?
    Thanks!
    "Perfection is achieved, not when there is nothing more to add, but when there is nothing left to take away." Antoine de Saint-Exupery (1900 - 1944)
    Mar 2009
    Okay, a few more details...
    On boot-up there is a keyboard error.
    I changed the BIOS so this no longer occurs.
    Now the error is:
    "HDD controller error"
    The hard disk seems to spin and work mechanically. My thought is a corrupt boot sector or the controller card has failed. I believe the former is more likely.
    Does anyone know how to re-install the boot info and where to get it? I have a floppy that will boot, can I get those files on to the HDD?
    Thanks!
    Moderator
    Nov 2004
    Are the CMOS parameters for the hard drive correct?
    Do you know how to attach a full size keyboard?
    Do you know how to get to DOS?
    What version of DOS is being used?
    George
    Mar 2009
    Quote Originally Posted by machintek View Post
    I believe so. The HDD used to work fine and there has been no changes to the CMOS since then. However, when I had the CMOS check the HDD parameters, it could not find the HDD.
    Yes.
    No. I tried hitting F8 on boot up, but it didn't work.
    Don't know.
  1. 2 axis Series I EZ Trak boot disk?
    By gripper in forum Bridgeport and Hardinge Mills
    Last Post: 02-07-2013, 09:49 PM
  2. EZ-TRAK boot up problem
    By kavmor in forum Bridgeport and Hardinge Mills
    Last Post: 10-11-2011, 04:16 PM
  3. Need Help!- EZ Trak boot failure
    By swatkins in forum Bridgeport and Hardinge Mills
    Last Post: 11-10-2010, 06:02 PM
  4. Bridgeport EZ-Trak SX boot files
    By drail in forum Bridgeport and Hardinge Mills
    Last Post: 05-13-2010, 10:58 PM
  5. Need Help!- boot problem
    By claucampan in forum Fanuc
    Last Post: 08-14-2008, 02:33 AM
