Old 12-28-2011, 08:09 PM
jmccracken is on a distinguished road
Bridgeport Interact w/ Heidenhain 151B - Traverse Speeds for Homing Axes
So my next question to you guys is how to control the traverse speeds during the axes homing operation, again with an Bridgeport Interact running the Heidenhain 151?
I recently learned where the feedrate parameters for rapid traverse (parameters 1 - 4) are different than those used in "PLC Positioning", (parameters 163 - 166). An example of the "PLC Positioning" move is an M25 command (retract spindle) ... which is, evidently, not governed under regular rapid traverse speeds.
Anyway, the machine seems to home incredibly fast regardless of what I set parameters 1 - 4 or 163 - 166 ... sometimes resulting in the spindle axis (Z-axis) over-running its stops. Interestingly, these speeds do respond to adjustment in the feedrate potentiometer on the control panel.
Is there a machine parameter governing the traverse speeds during homing?
Old 12-29-2011, 06:27 AM
John Bennett is on a distinguished road
TNC
I would take a look at parameters 8 - 10 (11) and 53 (see attachment).
Old 12-30-2011, 03:58 PM
You are correct ...
Bridgeport Interact 412/Heidenhain TNC 151 HELP? larrynsr Bridgeport and Hardinge Mills 16 03-17-2012 02:21 PM
Interact w/ Heidenhain 151B FeedRate Question jmccracken Bridgeport and Hardinge Mills 7 12-28-2011 06:54 PM
Need Help!- Bridgeport Interact 1 MK 2 Heidenhain 151 tommo61 Bridgeport and Hardinge Mills 8 11-30-2011 04:35 PM
Need Help!- Bridgeport Interact 1 - Heidenhain TNC 151 Monitor mattgatten Bridgeport and Hardinge Mills 6 07-04-2010 03:34 PM
Newbie- How do I "Traverse Axis"? Bridgeport Interact 1 Mk2 TNC 155 MeTri Bridgeport and Hardinge Mills 5 12-27-2009 05:10 PM
