Old 12-22-2011, 03:38 AM
tommo61 is on a distinguished road
Bridgeport Interact 1 MK 2
We have problem with spindle motor that cuts out and knocks all feeds out as well, (its as if emergency stop has been hit)this usuallly happens after about 3 hours from switching on. When we switch off for 1 hour and then back on it will run for about 2hrs. We think it could be spindle temp cut out thats causing this, anyone got any solutions.
Old 12-23-2011, 09:34 AM
Moderator
machintek is on a distinguished road
Make sure phasing is correct and the fan at the bottom of the spindle motor is blowing UP and not fighting a natural chimney of hot air rising.
When the brushes get short on the spindle motor it cannot conduct current through the armature and the revs drop under load. If the control sees a reduction of 20% of commanded spindle speed it stops the feed untill revs come back up.
George
Need Help!- Bridgeport interact 412 la1508 Want To Buy...Need help! 0 07-09-2010 04:52 PM
Bridgeport interact 1 mk2 Harb Bridgeport and Hardinge Mills 1 06-13-2010 04:14 AM
Need Help!- bridgeport interact 412 generaloceanics Bridgeport and Hardinge Mills 0 04-14-2010 09:35 AM
Newbie- Bridgeport Interact 412 eng101 Bridgeport and Hardinge Mills 4 11-29-2008 04:38 PM
Bridgeport Interact 1 MK2 Leyland 472 Bridgeport and Hardinge Mills 3 10-20-2006 06:44 AM
