Old 12-16-2011, 02:49 PM
vonslatt's Avatar
vonslatt is on a distinguished road
Bridgeport Series II Retrofit & Spindle Speed Question
Hi Everyone,
I just finished converting a Series II to Mach3 control:
Bridgeport Series II CNC Gecko/Mach3 Conversion | The Steampunk Workshop
and am learning how to use it:
Craftsman Compressor Seal Repair - My First CNC Part! | The Steampunk Workshop
My question is this: The spindle goes to 4000 RPM but the part of the speed indicator from 3000 to 4000 RPM is marked in red. Is there limited run time at these speeds? If so, how long?
Thanks!
Jake.
New Machine Build- Another Series 1 Bridgeport Retrofit deanq Vertical Mill, Lathe Project Log 11 05-04-2012 06:55 AM
Need Help!- Bridgeport CNC Series 1 BOSS 4 (5?) Retrofit mbshopman Bridgeport and Hardinge Mills 2 12-17-2011 07:38 PM
Bridgeport Series 1 MK 2 retrofit colin1544 AjaxCNC Control Products 1 09-30-2008 01:04 PM
Bridgeport Series II un-retrofit. Buddy0228 Bridgeport and Hardinge Mills 2 05-01-2008 02:39 PM
Bridgeport Series II Retrofit Cold Fusion Vertical Mill, Lathe Project Log 143 06-30-2007 08:37 PM
