Bridgeport discovery 308 -dx32 I started getting an alarm while running "Spindle not running, can not cut". Machine would stop moving, but spindle still turning. At first it was sporatic, now everytime. It also shows F11 on siemens controller. I have checked spindle enable signal thru relay CR1(seems ok). I can command gcode to turn spindle and spindle will run, but as soon as I run machine the alarm will come on when spidle should start up. I have verified that the speed control voltage to siemens controller is working and changes voltage dependent on rpm. I am not sure what voltage (24 or 0) START SPINDLE on CR2 should have and should this change only when the spindle is running? THe output wires 61 and 62 both have 24 volts all the time? I swaped around relays CR1, CR2 and CR3 to verify it is not a failed relay. Any help appreciated. |
| Problem- Daewoo DMV3016 Mill Alarm (Spindle tool clamp/unclamp alarm) | nickhough | Daewoo/Doosan | 0 | 05-09-2011 11:22 AM |
| Need Help!- 750 ALARM SPINDLE-1 ALARM DETECT (AL11) | PICMAN | Fanuc | 9 | 03-27-2011 06:14 PM |
| Problem- mach3 spindle dro not working, spindle speed changing while jogging and running code | jasminder | Mach Software (ArtSoft software) | 0 | 02-23-2011 12:12 AM |
| 149 alarm spindle running need help!!! | duckslayer | Haas Mills | 2 | 07-25-2007 08:51 AM |
| Spindle not Running | Simon Lee | DIY-CNC Router Table Machines | 1 | 02-09-2007 11:56 AM |
