which is better a belt driven or a gear driven vertical milling machine? The local dealer here says that we are able to cut faster and deeper with belt driven machine. but my mentor says otherwise? |
| Both are old school. Integral spindles are the way to go, unless all you do is low speed stuff. For low end torque gear is better, but personally I would only go gear if it was a 50taper machine cutting cast iron or hard materials it's whole life. Belt drive is really only low end machines now days, IMO. |
| ill be cutting 1030 to 1050 and p20 metal. do you happpen to have a endmill carbide speed and feed chart? right now i dont know how to use it properly and efficient so i could cut fast and prolong the tool life. currently i use around 3000 to 8000 rpm and feedrate about 1000 to 2500. depth around .02 to .2 mm only. and the tip would still break. I read about it online that cutting to little and fast will only produce rubbing of the tool and heating the carbide will only break it. |
| direct driven or belt driven | jeremy0203 | Benchtop Machines | 5 | 07-26-2011 11:23 PM |
| Convert Gantry to Belt Driven Need little Help | dbtoutfit | DIY-CNC Router Table Machines | 4 | 02-22-2009 07:46 PM |
| Build Thread- 8020 & Belt driven. Need input :D | Nikonauts | DIY-CNC Router Table Machines | 1 | 12-28-2008 12:13 PM |
| belt driven CNC | jwest | DIY-CNC Router Table Machines | 1 | 11-29-2008 04:10 PM |
| Belt driven screw ? | tomcat47 | Linear and Rotary Motion | 10 | 01-29-2007 10:20 AM |
