Old 10-20-2005, 08:26 AM
zdude is on a distinguished road
EZ-Trak
Is it possible to program this machine using conventional G & M codes?
Old 10-20-2005, 07:32 PM
Moderator
machintek is on a distinguished road
Yes! But when loading, it is considered "other" files and must have a TXT extension. But unless you have a full size keyboard on the machine and know how to use a DOS editor, you cannot edit the program on the machine.
Here is something to try. Load a conversational program and while in the RUN mode, press the minus key. It will pull up the G and M codes the BMDC has converted it to.
George
