Old 11-13-2011, 07:20 PM
Zahnrad Kopf is on a distinguished road
FIST monitor, terminal, cable pin out needed
Does anyone actually HAVE a cable to read the FIST monitor? I need to make one to access the FIST diagnostics of my V2XT and cannot seem to find anything about the actual pinouts nor anything CLEAR about how to hook it up. I have found numerous references to it going from local port A to K3 of the FMDC. Right now, K3 goes to COM1 of my motherboard. How am I supposed to do this? Any help is appreciated. Thanks.
Old 11-13-2011, 10:48 PM
Moderator
machintek is on a distinguished road
If I remember correctly, The V2XT with a FMDC came with a plug attached to the RS232 DP25 port that allowed the Fist to be displayed on the machine CRT. There was a function key that allowed access to the System.
George
Old 11-13-2011, 10:49 PM
Moderator
George
Problem- Indramat DKS Drives... Comms cable needed john.charles Servo Motors and Drives 0 02-24-2011 05:21 AM
Porter Cable router motor dimensions needed. danmickey DIY-CNC Router Table Machines 3 12-28-2009 07:25 AM
Bridgeport R2E3 "Fist" monitor cable John Bennett Bridgeport and Hardinge Mills 0 06-26-2009 03:18 PM
Newbie- Fist CNC, Need guidance rcpilot82 DIY-CNC Router Table Machines 131 01-17-2009 10:35 PM
Monitor info needed gridley51 General Electronics Discussion 0 10-01-2008 02:57 PM
