So i started ripping into my 2J head, to find the source of the noise when running. I have it down below the timing gears and can't find anything bad. I just looked at the motor thinking i may need bushings for the vari-disk, but found quite a lot of room between the bottom shiv and the motor shaft. Am i missing something in there other than a new bushing? |
| Older motor adjustable Vari discs had black bushings epoxied in. they were very thin. Maybe .030 inch in thickness. And a key with a steel core and 3 side plastic. I never glued new bushings in because I had to guarantee my work and trying to maintain the disc running true in all axis (and balanced) is not easy so I would purchase new discs. Having said that the new motor adjustable varidisc from Bridgeport came with a molded Plastic (Turcite?) bushing and key. And was balanced. This new type bushing was a lot thicker than the original black inserts. George
| I Want to Buy a Custom Bushing | herring_fish | Want To Buy...Need help! | 3 | 07-06-2011 09:20 PM |
| Need Help!- cheap drill/pin bushing and pin ideas? is there a cheap bushing and pin out there? | 777funk | General Metalwork Discussion | 1 | 01-31-2011 04:29 PM |
| Bushing Material | larry53 | Mechanical Calculations/Engineering Design | 3 | 11-26-2009 10:42 PM |
| Is it possible to turn closed round bushing into C shaped bushing ? | vroemm | Linear and Rotary Motion | 7 | 06-27-2006 05:04 PM |
| Thomson Super 8 Linear Bushing question? | widgitmaster | Linear and Rotary Motion | 10 | 06-01-2006 07:18 AM |
