Old 11-08-2011, 01:45 PM
skippyfix is on a distinguished road
interact series 1 mk 2
can anybody please tell me what the led lites mean on the front of the KTK drive I have the led lights # 3,5,8,9 on and dispay sayes 00. the MTI-1 board does not come on and I get the spindal fault on controller, it has a new MTI board. Thanks
Old 11-08-2011, 03:06 PM
gridley51 is on a distinguished road
In this case red is good.These leds should be on when you first power up the drive.You could also have leds 6 and 7 instead of 5 and 8.
The 00 is the readout of the onboard meter.This was KTK attempt to make fault finding on these boards quite simple.
I seem to remember there are 9 or 10 things that can be checked with that meter.
These drives are phase sensitive.
Can`t be more specific as I`ve no experience of these drives in Bridgeports but I had them in three other milling machines.
I have just replaced one and I will say that these drives were way ahead of their time with abilities and options they had.
Old 11-08-2011, 07:01 PM
paul3112 is on a distinguished road
link
could be some info here http://www.cnczone.com/forums/bridge...1-1_board.html
Old 11-09-2011, 02:40 PM
interact series 1 MK2
so do all the leds light up at start?
Old 11-09-2011, 03:04 PM
Not all of them just the ones you have mentioned,
LED 3 is the drive healthy/ready output.
It`s strange that Led 3 is on and you have a spindle fault.Is the Led on the field card on?
When the control is powered up does the LED to the left of 3 come on? (I can`t remember the number of it.You have Led3 then two relays and then this other Led)
Does the contactor come in when you programme a speed?
When I have a drive problem I split it from the control and operate it with a battery box.
Old 11-09-2011, 03:10 PM
the led #2 left of # 3 does not come on and if you are talking about led #1 on feild card or the MTI-1 card does not come on. Thanks Skip
Old 11-09-2011, 03:39 PM
Skip,are the fuses on the field card ok?
I`ve sent you a PM.
Mark.
Old 11-09-2011, 04:08 PM
Mark I sent you a PM, and the fuses are good. Thanks
Need Help!- Bridgeport series 2 interact 2 Cyphertech Bridgeport and Hardinge Mills 8 02-14-2012 10:33 AM
series 2 interact 4 dcchip Bridgeport and Hardinge Mills 2 04-02-2010 10:43 AM
Need Help!- bridgeport interact 4 series 2 gideon233 Bridgeport and Hardinge Mills 3 02-15-2009 08:05 PM
Newbie- Interact 1 Series ll JRS Bridgeport and Hardinge Mills 2 02-01-2008 06:21 AM
