Old 10-24-2011, 08:16 AM
smellyfeet is on a distinguished road
VMC600 table removal
Hi.
We have a problem with the lubrication on our VMC600-22 digita in that the oil is not being pumped to the bearings and ball screws. It is getting to the small union under the motor-end cover but thats it...
I had a chat with Hardinge and they say you can only access the larger distribution under the table with the top of the table removed.
My question is, has anyone had any experience of removing the table or disassembly of the linear slides? (Is it just a case of removing the plastic bungs from the bottom of the slide rails and removing the bolts then disconnecting the ballscrew?)
I would be grateful for any help.
Need Help!- Series 1 CNC table removal TarHeelTom Bridgeport and Hardinge Mills 12 08-29-2010 02:01 PM
Need Help!- Drawbar removal hotrob1 General Metal Working Machines 2 06-02-2010 03:53 PM
Slag Removal? + d CNC Plasma and Waterjet Machines 3 03-15-2009 06:26 PM
Newbie- Bridgeport Table Weight and Removal JKENIK Bridgeport and Hardinge Mills 5 11-20-2008 06:58 AM
Mill Table Removal elnerdo Tree 3 09-14-2008 03:47 PM
