I picked up a Series II R2E4 that is not functional. Some of the electronics have been removed so I can't really assess the overall condition of the mill but the mechanical stuff seems to be in good shape. I would like to get it up and going with minimal investment so that I can make sure that there are no major (expensive) surprises as I proceed with a complete retrofit. My plan is to run Mach3. At least during the initial evaluation phase, I would like to use as much of the Bridgeport components as possible such as the servos (SEM), encoders(?), and maybe the drive power supply. However, I have no documentation on what it is that I have. I was thinking about buying one Dugong drive to test each axis using the existing drive power supply and encoders. I already have converted a Series I with steppers to run with Mach3 so I'm familiar with Mach3. Is this a good approach? Where can I get schematics for what I have? Any insight would be greatly appreciated. Thanks in advance. |
I've been too busy cutting metal with my retrofitted Boss5 Series I to devote any real time to the R2E4. I did check out the spindle motor and got it to run successfully on a VFD. I hope to eventually get the mill setup to run on single phase 220 volts so that I can move it home. I also picked up a QC-30 spindle for the R2E4 so that I can use my existing tooling. My attempt to drive the X-Y axes with little steppers that I had on hand failed. They just didn't have enough torque to overcome the friction so I need to pick up a servo drive to use the existing servos. |
| I do have the original servos. I just don't have drives for them. Since I had some small steppers and stepper drives, I thought that I would use them to check out the mill, to make sure that the mill was in good enough condition to justify the money and effort for a full retrofit. |
| Bridgeport R2E4 385 Retrofit Help | electromech31 | Bridgeport and Hardinge Mills | 9 | 03-01-2010 07:34 PM |
| Newbie- Sieg X1 retrofit with Linux EMC2, CNC Fusion retrofit kit and Gecko G540 | GreenLead | Benchtop Machines | 31 | 11-26-2008 11:55 PM |
| Need Help!- camsoft retrofit to a anilam crusader retrofit | bowlingmac | CamSoft Products | 44 | 07-24-2008 09:00 PM |
| r2e4 varispeed with retrofit. | najnielkp | Bridgeport and Hardinge Mills | 5 | 11-01-2006 09:06 AM |
| CNC BP R2E4 Retrofit wiring ID | Tom Long | Bridgeport and Hardinge Mills | 2 | 10-30-2006 07:53 AM |
