The hand pump is progressing. I have all the passages drilled, fulcrum machined and the brass piston sleve ready to go. I still need to turn the piston pump rod, and make the two valve poppets. Only had a few minor machining glitches since the broken drill in the pump cavity. I did end up drilling one of the passage holes in the wrong spot. I re-drilled the hole and will just plug off the wrong one.
I had accidently measured the wrong spots on the master cad mode.
Craig
LinkBack URL
About LinkBacks
