Old 10-04-2011, 09:13 PM
snackbar is on a distinguished road
spidle cartrage
hi i"m new to the site wondering i replaced the spindle cartrage in a bridgeport vmc1000xp3 everthing is working but the clamp/unclamp, it will not unclamp far enough, cylinder starts down then stops before moving forks. Any out look would be very helpful
THANKS
Old 10-05-2011, 06:28 AM
Moderator
machintek is on a distinguished road
Probably broken spring washers in it. No need to remove spindle. Remove cylinder on top, and remove nut from drawbar. Drop out drawbar and remove springs with a magnet or coat hanger. Note arrangement of washers. Very critical. Also a very special high pressure grease on them.
George
Old 10-06-2011, 02:13 PM
thank you oil/air cylinder needed oil blead....
Spidle drive fan mmckell Cincinnati CNC 4 12-31-2009 11:36 AM
TM-1 Spidle oil smittys800 Haas Mills 4 03-01-2008 10:42 AM
