Hey Guys, Seems no one can help me so far. Anyone have an example of putting in a G54 offset into thier ISO program for a TNC 2500 control. I have a vise set up in my mill, and I know the offset values, I am just not sure on this control how to program that in, and then will it cancel it self when I do an M6 for tool change? Or does anyone know who to contact at Hedeinhan to ask? Thanks. Andy |
| Do you want to use the datum table or just shift a block of code? Here's how I use the datum table on my 426, your 412 should work similar if not the same. Not my post, Plankman's code but I like the way it works. It uses G53 N1 G00 G90 Z0. M91 ; 7/8 DRILL TOOL - 14 DIA. OFF. - 0 G53 P01+1 LEN. - 0 DIA. - .875 N2 T14 G17 S400 N3 M06 N4 G53 P01+1 ; BRIDGEPORT VMC1000-HEIDENHAIN 426 ; BRIDGEPORT VMC1000-HEIDENHAIN 426-1 N5 G00 G90 G40 X+2.5 Y-4.3125 M03 N6 Z+2 M08 N7 G83 P01 +.1 P02 -2 P03 -.4 P04 +0 P05 35 N8 Z+.1 M99 N9 G00 Z+2 N10 Z+2 N11 M09 N12 G00 G90 Z0. M91 N13 M05 ; 1 INCH BULL ENDMILL 0.0313 RAD TOOL - 1 DIA. OFF. - 0 G53 P01+1 LEN. - 0 DIA. - 1. N14 T1 G17 S2500 N15 M06 N16 G53 P01+1 ; BRIDGEPORT VMC1000-HEIDENHAIN 426 ; BRIDGEPORT VMC1000-HEIDENHAIN 426-1 N17 G00 G90 G40 X-.134 Y-6.5385 M03 N18 Z+2 M08 N19 Z+.1 N20 G01 X-.134 Y-6.5385 Z-.025 F200 N21 X-.134 Y-5.7885 F400 N22 X-.134 Y+.1 |
| Thanks for the response. I guess I want to use the datum table because, I have a vice set up on my machine, and I want to use the corner as my reference. How do you get to the datum table? I can't find it in the manuals I have. Andy |
| Use the online editor, change the file type to .d and it should list all of the datums. The manuals are available on the HH website. Invaluable. Pick up the location and enter in in the datum table. Then use the G53 line like above before each tool like shown. |
| Thanks for the help so far, I downloaded a bunch of manuals but didn't find that exact part yet. I also did get the machine to communicate with my computer using easy DNC, but it freaks out and gives me an error while uploading the program "incorrect h". Do you know what that means? Also I put the tool files into Program 0, and just used a M06 t01 for example, but it didn't seem like it had the tool length while I was coming down to touch off at a certain point, so is that the correct place to put tool values? It did not like me trying to use a G99 a line before the M6 either. Are you available for phone support at all? $$ Thanks, Andy Last edited by Trucks; 10-03-2011 at 08:25 AM. |
| tnc 2500 M90 | kennyayr | Bridgeport and Hardinge Mills | 0 | 01-30-2010 07:50 AM |
| Problem- 2500 sy | STS_Kevin | Daewoo/Doosan | 6 | 01-27-2010 07:46 PM |
| Help Tnc 2500 | opa3279 | Bridgeport and Hardinge Mills | 2 | 02-24-2008 10:09 AM |
| Heidenhain 2500 | nycooh | General CNC (Mill and Lathe) Control Software (NC) | 0 | 08-17-2007 02:57 AM |
| Heidenhain 2500 - Programming Z Axis | palikalsi | General CNC (Mill and Lathe) Control Software (NC) | 0 | 03-26-2007 08:46 AM |
