Old 09-27-2011, 11:01 AM
DannyP is on a distinguished road
Hardinge Conquest T-42 spindle will not rotate in jog mode
I have a Hardinge Conquest T-42 (serial # SGA-2071-B) with Fanuc 18T.
Battery ran down on Fanuc controller for X and A axis. Did the Zero Return reset procedure on both axis'. Noticed during the X axis procedure we couldnt turn the spindle in "jog" mode. Only if we run a program. The C axis drive shows 2 dashed lines (not ready) on the LED readout. It runs fine in auto. Is there some type of reset or procedure that needs to be done on the C axis drive in order to be able to turn the spindle in jog mode?
hardinge conquest 51 mikemck Hardinge Lathes 1 10-15-2010 07:28 AM
Need Help!- Hardinge conquest 42 gyroxis Hardinge Lathes 1 09-20-2010 08:07 PM
Max Spindle Speed in Jog - Hardinge Conquest T42 drunkendave Hardinge Lathes 0 05-07-2010 10:38 AM
Need Help!- Hardinge Conquest 42 newc Hardinge Lathes 1 02-25-2010 06:10 AM
Hardinge Conquest 42 cncdiag Fanuc 1 05-20-2008 07:06 PM
