Old 09-23-2011, 03:05 PM
Suffolk miller is on a distinguished road
3 axis eztrak
I believe it is possible to dnc to this machine, does anyone know how, all I can get is how to save file to C drive. I want to run program from cad/cam editor.
Old 09-23-2011, 07:36 PM
Moderator
machintek is on a distinguished road
I know that the 3 axis trak has that capability. I remember seeing a DNC key, I believe under the run menu. Check your operating manual.
George
Old 09-24-2011, 03:35 AM
The DNC optiopn is in main menu "4" but then gives 2 options -save? and open macros - could that be the line to take?
Old 09-24-2011, 04:35 PM
Gncc50 is on a distinguished road
DNC EZtrak
Check out this thread. This should explain it for you.
http://www.cnczone.com/forums/bridge...dated_cpu.html
Pete
Old 09-26-2011, 07:53 AM
*Registered*
Bpt Service is on a distinguished road
DNC Stopping
One of the most important things is to get the program into the machine's "C:> Drive". There are many versions of the "Crive" throughout Bridgeport's history. There are actual physical hard drives, Disk on Chips (Max space 8Mb), Flash Disk Cards (8Mb) and currently Disk on Modules. The floppy drive does not run as fast as any of the various C: drives and because of the slow read/write time DNC will get hung up. Always copy your program first from floppy to HD, then DNC from HD.
Old 09-26-2011, 01:57 PM
Hi
I have come to the conclusion that these machines do not accept dnc. Running a whole program from "C" drive is not dnc. To dnc is to send direct from cad/cam, drip feeding if necessary with no limits on file size.
Problem- EZTRAK II DX Z axis drift dmac88 Bridgeport and Hardinge Mills 10 01-24-2009 03:54 AM
Problem- Eztrak X axis will not home sidstover Bridgeport and Hardinge Mills 4 11-11-2008 07:04 PM
Problem with my EZTRAK 3-axis Ingchema Bridgeport and Hardinge Mills 1 09-21-2008 01:47 PM
Problem with my EZTRAK 3-axis Ingchema Trade Shows and Events 0 09-16-2008 07:59 AM
EZTrak with factory installed 3rd axis. Gncc50 Bridgeport and Hardinge Mills 2 04-08-2006 01:13 PM
