Old 09-22-2011, 01:56 PM
GCoded is on a distinguished road
Explorer II / DX32 BMDC failures
I'm looking at buying a 3rd BMDC in less than 2 years.
(c prompt at "executive load").
After some searching I went through all the checks mentioned in various threads on here and went through the same process with EMI. EMI determined it more than likely is a bad BMDC.
Is there a reason why these boards go bad and why so often? Anyone have one last a long time?
Old 09-23-2011, 07:40 AM
Moderator
machintek is on a distinguished road
You did clean the edge connector with a soft eraser? Try a different ISA slot? Run the B3T test?
George
Old 09-23-2011, 09:59 AM
George
I do not have a B3T program that I can find.
Did a scandisk and defrag. No bad sectors or clusters.
Reinstalled o/s and dx32 software.
Checked powersupply voltage on startup and when running.
Checked and reseated all connectors.
Cleaned BMDC edge connector with eraser.
Changed ISA slot for BMDC.
Changed ISA slot for MB.
Started without each Bob card connected individually to BMDC (EMI).
Started without both Bob cards connected to BMDC (EMI).
Machine was running in the morning. Turned off machine, did belt tension adjustment and checked/cleaned Z axis servo brushes. Restarted machine and have been getting c prompt @ executive load ever since.
Ordered another BMDC card. Going to add a line conditioner for PS in case of any power issues.
Old 09-23-2011, 07:48 PM
Moderator
The B3T.exe is a test of the BMDC board. It identifies more specifically what the issue is with a BMDC. For a service tech, it verifies what is already known, that it needs to be replaced. Look in your hard drive. It might be there.
George
Old 09-26-2011, 09:57 AM
George
Thanks for your help George.
Unfortunately I'm not able to find that program on my machines HD.
Old 09-26-2011, 05:33 PM
cncbpt is on a distinguished road
I can email it to you if you need it
Old 09-27-2011, 12:08 PM
That would be great.
Sent you a PM with my email.
Thank you.
Old 09-28-2011, 05:30 PM
I sent it to you.
Let me know you got it ok.
Old 09-30-2011, 08:00 AM
Got it. Thanks.
I will put B3T somewhere accessible and will post the link to download here.
Old 10-01-2011, 04:18 AM
It would be nice to have a place we could put files so anyone who needed
them could download them from there.
I will check and see if this is possible from my website.
Need Help DX32 Control Explorer 1 Bridgeport TNBG_LTD General CNC (Mill and Lathe) Control Software (NC) 1 06-21-2011 04:51 PM
Need Help!- Post bridgeport explorer dx32 Tony Garacia Bridgeport and Hardinge Mills 0 03-23-2011 12:27 PM
DX32 Explorer Jumpy and Noisy in Jog johnhb Bridgeport and Hardinge Mills 5 08-19-2010 07:44 AM
Need Help!- Bridgeport Explorer I CNC with DX32 control minton Bridgeport and Hardinge Mills 7 01-27-2010 11:25 PM
Need Help!- Bridgeport Explorer I Boss DX32 minton Bridgeport and Hardinge Mills 2 02-12-2009 11:12 PM
