Old 09-21-2011, 12:44 AM
Farmer Machine's Avatar
Farmer Machine is on a distinguished road
Question bridgeport interact 1 mk2 supply voltage
I just bought a bridgeport interact 1 mk2 mill with a heidenhain tnc 2500 control. I didn't receive any manuals or schematics with it. According to the seller it is set up to run on 460 vac. I looked in one of the control cabinets and there is an auto transformer with taps for many different voltages from 200-480 volts. It is currently tapped for 460-480. I was wondering if I could just change the taps around for 220-240 and turn the machine on. My only concern is that there may be other transformers that have to be re-tapped... Also, I will be running this on a phase converter, but have no idea what size to use. Any advice will be appreciated. Thanks.
Tags
bridgeport, interact, mk2
Bridgeport Interact 2 -- tachometer mode vs. voltage mode? ichudov Bridgeport and Hardinge Mills 2 06-28-2010 01:24 PM
Need Help!- Interact Series 1 Mk2 - EXT DC Voltage Missing MeTri Bridgeport and Hardinge Mills 3 05-23-2010 08:38 AM
BT Interact 412 - RELAY EXT. DC VOLTAGE MISSING Zhales Bridgeport and Hardinge Mills 11 04-13-2009 04:42 PM
Bridgeport Interact 1 MK2 - Input Voltage palikalsi Bridgeport and Hardinge Mills 20 11-07-2008 07:42 PM
Bridgeport Power Supply - what voltage? damae Bridgeport and Hardinge Mills 3 02-03-2006 04:13 AM
