Old 09-10-2011, 04:46 PM
md63825's Avatar
md63825 is on a distinguished road
BobCad for Programming TorqCut 22
Anyone use BobCad to program their TorqCut 22? I used the DX-32 post on their website.
Here's the issue: I created a program in BobCad and used the Subprograms Option. It created a program with Subprograms but I am new to the TorqCut 22 so I was wondering if I need to create a separate file for each of the subprograms that BobCad produced. In the current file, the subprograms are all contained in one file (see attached). On my EZTrak I can create a main program and call-up each subprogram, which are separate programs. I can then use workshifts to run the same program at different workshift locations on a fixture plate.
Old 09-10-2011, 05:14 PM
jvangelder is on a distinguished road
what you have posted is very similar to what i post from bobcacd to both fanuc and fadal machinees. Besides the fanuc 6M, ive never had problems sending mulitpul programs (main and sub) all at once. The 6m i always have to send them one at a time
fwiw, my posts look like
O1234
bal blah
M30
O1001 (sub of 1234)
M99
O1002 (sub of 1234)
M99
Old 09-11-2011, 08:41 AM
md63825's Avatar
Individual Programs?
In this situation, the Sub's are all contained in the single program that Bob-Cad created. Did you cut the subprograms from the main program and make them into individual programs or leave them in and run it as one single program? My experience has always been to create a main program and call-up the sub's, which are separate files. I thought this was how it was normally done so you have multiple smaller files. The benefits would be 1) instead of having on large file that won't fit onto a floppy disk, you will have several smaller files that can be loaded from more than one disk. And 2) is being able to use multiple Workshifts. If I want to run that part on workshift 1, 2, 3, 4, and 5 or just 1 and 2 it is a simple modification to the Main program.
Tags
bobcad, dx-32, subprograms, torqcut
BPC-MC control - Torqcut TC-1G nlh Bridgeport and Hardinge Mills 13 08-05-2009 01:03 PM
Monitor went out on TorqCut-22 with DX32 Control MetalicGlow Bridgeport and Hardinge Mills 6 04-07-2008 11:07 PM
Torqcut 22 computer gokarter Bridgeport and Hardinge Mills 3 01-20-2008 01:21 PM
TORQCUT 22 limey44460 Bridgeport and Hardinge Mills 4 01-11-2008 06:15 AM
TorqCut 22 - belts numbers needed? RedGTZ Bridgeport and Hardinge Mills 2 12-18-2006 12:18 AM
