I came across this site looking for info on my setup. It seems I started having a no start issue on my 86 BP after I tilted the top part to a 45* to machine a part. It would not work with how I needed to machine the part so I put it back to 0 and when I turned the switch to run on high/forward and spindle does not turn on nor hear any noise like wanting to start. I saw a thread about a low level issue but only have a oiler on the side of the mill where I pull the handle up to self lube. Any help?? Thanks in advance Mike |
| Hi NoriBilt- punchpressman probably has the answer, me being a "cause and effect" kinda guy, but you might want to check that oil level. The Bijur pump is electrically interlocked (at least on both my BOSS 5 & 6) with the start circuit. It will not stop during a run cycle, but if the oil level is low, it will not allow the spindle to start. Might be too coincidental, but just a thought. CD |
| If you have a meter or even a voltage tester, I would check to see if you have power at the on/off switch. The Bijur pump may not have the interlock. If there are wires running to it then yes. If not it is a standard one-shot manual pump and would not have the low fluid level interlock. I would just go over all the basics again. Wire connections, fuses, etc. |
| Need Help!- R2E3 Series 1 Startup Issue | rrperformance | Bridgeport and Hardinge Mills | 2 | 02-03-2011 12:26 AM |
| Need Help!- Bridgeport DX Series 2 Boot Issue | Coolbreeze22 | Bridgeport and Hardinge Mills | 22 | 12-02-2010 03:25 PM |
| Need Help!- Allen Bradley 9 series EOB issue | J5P332 | General CNC (Mill and Lathe) Control Software (NC) | 1 | 05-20-2008 01:22 PM |
| Bridgeport series I V2XT software issue? | biggs | CNCzone Club House | 0 | 05-17-2008 08:00 PM |
| Series 1 Power Issue | markhas | Bridgeport and Hardinge Mills | 5 | 08-10-2006 05:35 AM |
